Does your Song Plus automatically realign the steering when you make small adjustments on the highway? Is there a lot of resistance when you adjust with one hand?
The steering wheel is really sensitive... There's no resistance when you turn it slightly left or right, it's like steering an air wheel [facepalm]. You only feel resistance after that gap! You really have to hold it with both hands when driving on the highway!! [facepalm][facepalm] Do you guys experience this too?!!
Does anyone feel that the steering of the Tucson tends to drift on the highway? I constantly need to make small adjustments. Is there no self-centering, or is there a setting for this? It's quite tiring to drive like this.
HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
4When the steering of the 2017 Honda City is turned fully, there is a stuttering, as if it's stuck, but there is no issue with small turns. What could be the reason for this? Can anyone help with this? Thanks a lot.
5Changan CS35 Plus makes a strange noise when turning the steering wheel while stationary.
6When driving the Song Plus fuel vehicle at high speeds, subtly adjusting the steering feels like the steering wheel is sticky and requires some effort to push. It feels heavy, and I have to constantly correct it without any self-centering rebound force. What's going on?
7Does your Song Plus automatically realign the steering when you make small adjustments on the highway? Is there a lot of resistance when you adjust with one hand?
8Does your car's steering wheel automatically return to center when you make slight adjustments at high speeds? When you make minor adjustments with one hand, do you feel a lot of resistance?
9Hey folks, does the steering wheel of your BYD Song PLUS gasoline version feel heavy? Mine feels quite heavy when driving, and I'm not sure if this is just how the car is or if there's an issue with my steering system.
10I'm torn between the Song L and Song Plus. I'm leaning more towards the Song L, but I noticed that the Song L has a metal fuel tank, while the Song Plus has a plastic one. It seems like the plastic fuel tank might be safer. What do you all think?
