حكم سلمان
2024-11-26 09:40
Does your car shake that badly? Have you experienced this? I've been told several times while sitting in the back seat at a red light. Is there a problem that can be fixed?
عبد العزيز إبراهيم
عبد العزيز إبراهيم2024-11-27 16:20
You can check the engine PCV valve. I had a similar issue where I felt vibrations while sitting in the car.
نعيم عبد العزيز
نعيم عبد العزيز2024-11-27 07:07
The new car is shaking at the position of the front passenger seat and the rear seat on that side.
نايف مبارك
نايف مبارك2024-11-26 19:28
Idle is unstable, check the spark plugs and throttle body.
I've been driving the T8PRO diesel 4WD for less than half a year, and it's been having engine emission issues all the time! I have to go to the service center at least once a week for diagnostics. I'm wondering if this problem can't be permanently fixed...
Today, my car sometimes shakes while driving. It shakes for about 2 minutes and then goes back to normal. Anyone know what the issue might be? Thanks in advance!
Is there a good way to fix the plastic noise in the gear shift of the 2019 Classic Sylphy? I've been to the dealership four times, but they haven't fixed it!
Is there a problem with the car if the auto start-stop system, once activated at a red light with a deep press, automatically reignites due to the long red light duration and causes noticeable shaking?
What could cause the MG ZS to idle roughly? The shaking is more severe with private fuel, while it's milder with state-owned fuel?
Hi everyone, I've been having issues with my Hongqi H7 where the side mirrors often don't fold when I lock the car and the seat adjustment occasionally fails too. I noticed these problems tend to occur together. I had the wiring checked and charged the battery, which fixed it for a while, but then it started happening again. I thought it might be the battery losing charge, so I replaced it. It was fine at first, but then the problems came back. The mirrors fold manually without any issues inside the car; it's just when I lock the car that they don't fold, and the seat adjustment also fails!
After driving my car for a while, I keep getting notifications that the transmission needs maintenance. I've gone several times but it hasn't been fixed.
Is there a good way to insert the airbag clip under the driver's seat after it's been removed? It's really hard to put back in.
How to fix a leaking sunroof on a Kodiaq? I've tried several times, but it still hasn't been fixed.
BYD BYD Song Plus
BYD Song PlusAED 118,900 ~ 143,900Hybrid
