حسن لاويل
2024-07-10 08:25
Does your car's steering wheel automatically return to center when you make slight adjustments at high speeds? When you make minor adjustments with one hand, do you feel a lot of resistance?
نايف مبارك
نايف مبارك2024-07-10 10:49
My steering wheel won't return to center. Anyway, I keep my hands on the wheel while driving on the highway. It's normal to feel some resistance.
What causes the steering wheel not to return to center automatically?
The steering wheel is really sensitive... There's no resistance when you turn it slightly left or right, it's like steering an air wheel [facepalm]. You only feel resistance after that gap! You really have to hold it with both hands when driving on the highway!! [facepalm][facepalm] Do you guys experience this too?!!
Does anyone feel that the steering of the Tucson tends to drift on the highway? I constantly need to make small adjustments. Is there no self-centering, or is there a setting for this? It's quite tiring to drive like this.
Does your Alto automatically return to the center when you turn the steering wheel?
HS 30T 2WD, when driving on the highway, the steering feels sticky and doesn't return to the center, making it tiring to constantly adjust. This doesn't happen at low speeds or in hot weather. Has anyone else experienced this? How did you solve it? Some say it's an issue with the steering gear and needs a full replacement—is this true?
Does your Song Plus automatically realign the steering when you make small adjustments on the highway? Is there a lot of resistance when you adjust with one hand?
Why is the steering on my 2018 X-Trail heavy and not returning to center automatically?
Steering feels stuck and doesn't return to center. How do you guys deal with this? I've heard it can be fixed by reapplying grease to the steering gear. How much does it roughly cost?
BYD BYD Song Plus
BYD Song PlusAED 118,900 ~ 143,900Hybrid
