سعود عابدين
سعود عابدين
Dec 1
The Sonata 11 1.5T Pro seems to have issues with vibrations when driving, making it uncomfortable and causing numbness in the body and feet. However, there are no vibrations at idle. What could be the problem?
Comments( 6 )
فهد عاطف
فهد عاطف2024-12-03 06:57
I've driven 2000 kilometers so far, and haven't noticed anything yet.
عبدالرحمن موجا بطاقة تعريف
عبدالرحمن موجا بطاقة تعريف2024-12-01 21:13
You can go to the 4S shop to have the oil pipe wrapped to fix the resonance issue.
عبدالرحمن نور
عبدالرحمن نور2024-12-01 21:02
If you feel there's an issue, just go to the 4S shop and have it checked. I've driven 4,000 kilometers and it's been great. 😁
خالد مدرسي
خالد مدرسي2024-12-01 20:27
There is no such issue.
حسن ميثا
حسن ميثا2024-12-01 19:37
Because you're a paid shill.
عبدالله خضير
عبدالله خضير2024-12-01 19:33
It's just in your mind, I didn't feel anything.
When driving over 120 km/h, the steering wheel and accelerator cause numbness in my hands and feet due to vibrations. Even slight unevenness on the highway results in rhythmic vibrations, making my hands and feet feel numb.
The air conditioning isn't cooling. I checked the pipes and found no leaks. However, after adding refrigerant, it was gone in less than two months. For an 11-year-old imported Mazda CX-7, what usually causes this issue?
What could be causing severe idling vibration?
I have a 2018 GS7, and the engine vibrates a bit when idling. There's also a slight ticking noise when driving, which started recently. Can anyone help me figure out what might be causing this?
The engine warning light is on, and the idle seems unstable. The speed can still go up, but it doesn't accelerate as quickly as before. Could it be a problem with the throttle? Any insights?
What could be causing the severe idling vibration in the x95? It's at 5.5 kilometers. How can I resolve this issue?
What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
Haval H2 Red Label 1.5T has currently run 85,000 kilometers. While driving at speeds between 60 to 100 km/h, there's a vibration and noise coming from the front wheels. What could be the cause of this issue?
Hyundai Sonata
Hyundai SonataKWD 6,250 ~ 9,300Gasoline & Hybrid & Petrol
