When the car starts, it's quite noisy, but the noise stops after a while. Can anyone check what might be the reason for this? Is it normal?
After turning off the car and walking to the rear, there's a gasoline smell, but it disappears after a while. Does anyone know what the issue might be?
What could be the reason for the start-stop system not working on the 2017 model?
4When I turn on the AC, it makes a noise... After a while, it gets a bit better, but when I stop the car, it starts making noise again... Has anyone experienced this? Thanks.
5Is the engine of the 2018 automatic model noisy while driving? Has anyone experienced something similar?
6Today, after starting the car, the engine vibrates quite severely, but after a while, it gets better. Does anyone know what the reason might be?
7Why does my car's radiator show high temperature after driving for a while? Does anyone know the reason?
8The battery status is normal. What could be the reason for not being able to start the engine after turning it off?
9Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
10When the car starts normally and the brake pedal becomes hard after driving a certain distance, what could be the reason?
