حسين حسن
2024-09-21 10:43
What should I do if the touchscreen stops working? The dealership said it's a common issue, and since it's out of warranty, they suggested I replace it myself (which is quite honest of them). Has anyone else encountered this problem? Which type of screen is suitable to replace it with? 😊
عمر طاهر
عمر طاهر2024-10-10 21:21
Buy an external screen and a pentalobe screwdriver on Taobao, and just replace it. The seller usually provides a tutorial. Personally, I don't think it's too difficult.
علي توفيق
علي توفيق2024-09-21 21:20
Repairing a 300, replacing with a new screen.
My RDX has hit 90,000 kilometers, and the dealership also suggested replacing the tires. I wonder which tire models everyone else has switched to? Feel free to share the specific brands and models! Tires with the same specifications for other cars are also welcome, like 235/55R19. 👍
Which coolant should I buy for the imported Koleos? I noticed today that the coolant in the reservoir is below the minimum line and I'm considering replacing it all. Could you advise on which coolant would be suitable?
Guys, has anyone had to replace their steering gear? I changed mine after just over 5,000 kilometers, and now it's making noise again. Every time I turn, there's a cracking sound! Is this a common issue? The warranty is about to expire, and if it happens again, I'll have to pay out of pocket. It's really frustrating.
My car was registered in 2018 and has just over 10,000 kilometers. It's been in the repair shop for half a month now. They said it's the electronic rocker arm that's broken. First, they tried replacing the spark plugs, but that didn't work. The ignition coil didn't work, and neither did the injectors. Then they said it's the electronic rocker arm. Wow, it costs 12,000. Sigh, they suggested I replace the engine, which is around 15,000. I don't even know what to do. This car isn't worth 50,000 now, and fixing it costs over 10,000.
Hey guys, one of my bulbs burned out and I want to replace it myself. Which model should I buy? If anyone knows, please let me know. Thanks!
Hi everyone, the electronic steering lock of my Chery Jetour X70 is broken and needs to be replaced. The 4S shop said it's no longer under warranty, so I have to replace it myself. It seems to cost several thousand. Does anyone know if the 10-year or 200,000 km warranty indicated by the lifetime warranty badge on Jetour still covers it? The steering system is an important part of the car. The car was registered in August 2020, so it's been almost four years. Does anyone know if this is still under warranty? Please help.
I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
How to fix the long brake travel on a 2014 Santana? The brake pads are thick, the rear drum brakes have been tightened, and the brake fluid has been changed. Recently, the brake travel has become longer, and I'm not used to it at all. When I press the brake, it feels like there's a hissing sound under my foot. Several mechanics said they can't adjust it. Any suggestions on which part needs to be replaced? Thanks!
Let me share my experience as well. I also have a 2017 MG ZS, one of the first batch from July, manual top configuration. Since then, apart from other issues, the main problem has been the car cutting off power when starting. The entire car loses power, and it won't start. It's fine today, but not tomorrow. The car often won't start. I've replaced several batteries and small parts, but the issue remains. Sigh, I'm disappointed. The car is still at the repair shop now, I'm afraid to drive it. If it stalls, it won't start again, which is frustrating. I used to be a loyal MG fan, but I'm really disappointed now. Next time I change cars, I won't choose MG anymore. Does anyone know what the problem might be?
