خالد منذر
2023-03-16 14:31
The heated rearview mirror isn't working, but the electric adjustment is fine. I've been to several repair shops, and they all say I need to replace the base, which costs over 2000 for an original one. Any experts here who can give some advice? Thanks!
Comments( 6 )
خالد منذر
خالد منذر2023-04-27 16:45
Is it unclear? Do I need to scan the code?
ربيع خالد
ربيع خالد2023-04-26 08:24
Looking for advice, my side mirror doesn't tilt down automatically when reversing. What's going on with this?
خالد منذر
خالد منذر2023-03-18 10:45
I checked the manual yesterday, and indeed, it doesn't heat below 20°C.
محمد تكريتي
محمد تكريتي2023-03-17 20:23
The heating system has a temperature limit and does not activate above 20°C.
خالد منذر
خالد منذر2023-03-17 06:18
I checked the manual, and indeed the heated side mirrors can only function below 20 degrees. [Thumbs up][Thumbs up][Thumbs up]
2
سلمان إدريس
سلمان إدريس2023-03-16 19:04
Maybe the side mirror isn't broken. Remember, the Sharan's side mirror heating only works when the temperature is below around 20 degrees. If the temperature exceeds this, it automatically stops. This is exactly what happened with mine.
Do you experience jerking with your S40? After repairing the oil leak on mine, the low-speed jerking became very severe. I spent 7000 to repair the transmission, but there's still slight jerking. When starting, it jumps to 3000 rpm and then drops to 2000 rpm, with a fuel consumption of 15. I've already spent 10,000, and people say it's an old car, so it's normal. I'm wondering if you guys have experienced this situation!
Is the maintenance cost for the 720s high? I've been looking into it for several days and I'm really tempted. Planning to buy one next year to drive to school for fun. But I've heard you guys say it has a lot of small issues. I don't plan to drive it often, so what's the approximate monthly maintenance cost? My family is kind of like "only pay for the purchase, not for the upkeep" [crying]. At the same time, I also need to maintain another four-seater car (not exceeding 500,000).
The center console screen of the 2017 Renault Koleos is not turning on. The 4S shop says the main unit is broken. How much does it cost to replace the main unit?
Hi everyone, the electronic steering lock of my Chery Jetour X70 is broken and needs to be replaced. The 4S shop said it's no longer under warranty, so I have to replace it myself. It seems to cost several thousand. Does anyone know if the 10-year or 200,000 km warranty indicated by the lifetime warranty badge on Jetour still covers it? The steering system is an important part of the car. The car was registered in August 2020, so it's been almost four years. Does anyone know if this is still under warranty? Please help.
When starting a cold car, the idle speed takes 5-6 minutes to drop below 1000 RPM, and the engine vibrates. I thought the throttle was dirty, cleaned it, but it didn't help. The oxygen sensor current shows -0.01 mA. The repair shop says it's fine, but I feel like there's an issue. What could be causing this?
Help needed! I have a 2017 model 95. With summer here, there's white smoke coming out at startup, but it goes back to normal after a few seconds. There's no lack of oil or water, and the computer diagnostics show everything is fine. I've been to several repair shops, but no one has found the problem. Has anyone else encountered a similar issue?
Is it reasonable that the 4S shop says it costs 2000 to register an imported Crown?
Hello everyone, for those who bought the Jetta VS7 Automatic Glory Edition, do the features like anti-glare rearview mirror, electric tailgate, magic box, hydraulic strut for the electric tailgate, and welcome lights require an additional optional package costing four thousand? Appreciate any sincere advice from you all.
