The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
4Hi everyone, I need some advice. The central locking system on my 2018 Dongfeng Renault 2.0 Koleos is acting up. Sometimes it works, sometimes it doesn't. What could be the problem?
5What could be the issue if the radiator fan of the Haima S5 only operates when a blower is used, and doesn't turn on even after driving for a long time?
6My 2013 Sharan's electric door sometimes won't close by itself, and the button doesn't work either. After disconnecting and reconnecting the power, it works again. Does anyone know the reason?
7What could be the issue if the fan doesn't turn on at 90°C for a 2016 manual XINRUI?
8Hey folks, the touchscreen on my Sharan sometimes doesn't respond well, and the circulation button also occasionally acts up. Any ideas on what's going on? Looking for some advice!
9When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
10Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
