The cigarette lighter in the central armrest box and the trunk has no power. Please advise.
Where is the fuse box for the cigarette lighter?
The dashboard shows a headlight malfunction. How can I fix this? Has anyone encountered this before? Please advise.
Hey folks, the cigarette lighter below the center console in my Sportage has power, but when I plug in the car charger, there's no response. The charger is good. What's the issue?
4Which fuse controls the power for the cigarette lighter?
5After the power reset of the Coaster, the fault code light is on and it can't accelerate. What's going on? Can any expert advise, please?
6Is there anyone who has experienced the car cigarette lighter charger not charging the phone when it's not in use, and the battery level actually decreasing instead of increasing?
7How to replace a broken cigarette lighter in the trunk?
8The cigarette lighter in the central armrest box and the trunk has no power. Please advise.
9The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
10How can I install a central control switch for the trunk of the X90? If anyone has upgraded this, please share some knowledge. Currently, I can only open and close it with the key from inside the car. It would be more convenient to have a button on the central control.
