Should I replace the oil pressure sensor on a 2017 1.4T Sharan? Is the original sensor an improved version?
How do I replace the headlight bulb on a Sharan?
How did you deal with the issue of the water temperature sensor malfunctioning and the temperature light constantly flashing? I replaced the temperature sensor, but it started flashing again after two months. Did you replace the thermostat assembly? 2017 model.
What kind of engine oil should I use for a 2017 model 95 4WD?
4What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
5The original halogen headlights on the Sharan were replaced with LED headlights, and they flicker during start-stop. Should I use 5054 to activate the xenon mode for the low beam to stop the flickering?
6Should I replace the oil pressure sensor on a 2017 1.4T Sharan? Is the original sensor an improved version?
7Is the oil pressure sensor on the 2017 1.4T Sharan an improved version? Should it be replaced?
8Is the oil pressure sensor of the 2017 Sharan 1.4T, manufactured in January, an improved version? Should it be replaced?
9What type of engine oil should I use for the 2016 Sharan 1.4T? Any suggestions from the experts here?
10Hi everyone, for the transmission oil of Pama, should we use the original one or is ZF oil okay? ZF is half the price of the original. Some people say the original oil is also made by ZF.
