Is the third-generation 888 engine, with 70,000 kilometers on it, now burning one liter of oil every 5,000 kilometers? I've always used Castrol Edge 5W40 oil. Does it need a major overhaul?
Comments( 7 )
2011 MDX makes a knocking sound like "da da da" when accelerating, occasionally shakes during acceleration, and consumes 1 liter of oil every 2000 kilometers. Should I consider an overhaul?
Does the transmission oil need to be replaced for a car registered in 2017 with over 70,000 kilometers?
How should I deal with my Kia Sportage burning oil after 120,000 km? Does it need a major repair? Has anyone else experienced this? Can you share your thoughts?
4Can the original engine oil of the 90 Zilong Edition last for 10,000 km before needing a change? Changing it every 5,000 km seems too frequent.
5Is the third-generation 888 engine, with 70,000 kilometers on it, now burning one liter of oil every 5,000 kilometers? I've always used Castrol Edge 5W40 oil. Does it need a major overhaul?
6For the 2011 VW Touran with a manual transmission, it's generally recommended to use high-quality engine oil that meets the manufacturer's specifications. A popular choice is synthetic engine oil from brands like Castrol, Mobil 1, or Shell. Always ensure the oil meets the VW 502.00 specification for optimal performance.
7I'm considering getting an old Outback and I'm torn between the late fourth generation and the early phase of the fourth-and-a-half generation. From what I've read, many posts say that the last EJ25 doesn't burn oil as severely as the first FB25.
8Do I need to change the transmission oil for a 2019 GAC GS5 Elite version with 70,000 kilometers on it?
9How often do you guys do maintenance? Every 5,000 kilometers?
10What type of engine oil should I add to my Prado 2700 that has run over 180,000 kilometers but doesn't burn oil? Thank you, everyone!
