Is the oil pressure sensor on the 2017 1.4T Sharan an improved version? Should it be replaced?
For a 2017 Honda City with 90,000 kilometers, what type of engine oil should be used? Should it be 20 or 30?
Does the transmission oil need to be replaced for a car registered in 2017 with over 70,000 kilometers?
How did you deal with the issue of the water temperature sensor malfunctioning and the temperature light constantly flashing? I replaced the temperature sensor, but it started flashing again after two months. Did you replace the thermostat assembly? 2017 model.
4What kind of engine oil should I use for a 2017 model 95 4WD?
5What should I pay attention to when maintaining a Vitara 1.4T automatic? Which brand of engine oil and filter is better? How often should the air conditioning filter be replaced? At how many kilometers should the original spark plugs and brake fluid be replaced, and what brand of battery is recommended to be replaced with?
6What maintenance should be done at 100,000 kilometers? Do the transmission oil and gear oil need to be replaced?
7Should I replace the oil pressure sensor on a 2017 1.4T Sharan? Is the original sensor an improved version?
8Is the oil pressure sensor on the 2017 1.4T Sharan an improved version? Should it be replaced?
9Is the oil pressure sensor of the 2017 Sharan 1.4T, manufactured in January, an improved version? Should it be replaced?
10What type of engine oil should I use for the 2016 Sharan 1.4T? Any suggestions from the experts here?
