حسن شمس
2023-06-10 07:33
Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
سلمان حليم
سلمان حليم2023-06-13 06:49
Cooling is a normal phenomenon. If you're worried, have the antifreeze and radiator checked.
The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
Does anyone else experience wind coming through the headliner when the AC is on (especially when the fan speed increases)? I can feel a noticeable draft when I touch the driver's side seal. There's also a whistling sound when the windows are closed. Is there a car owners' group? I'd like to join.
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
The outside temperature is 15 degrees Celsius, but it's hot inside the car without opening the windows. What's going on?
Has anyone experienced a noise from the front right wheel, like a screeching sound, especially when lightly pressing the brakes or driving at 20-30 km/h after braking? The noise is very sharp.
