عبدالرحمن خديجة
2024-02-16 15:11
I'm getting ready to change my tires. Has anyone switched to 225/55/17? Are there significant differences in comfort and handling?
محمد يحيى
محمد يحيى2024-02-24 14:23
I switched to Pirelli. I originally wanted to go for Continental, but it was out of stock.
فهد حموي
فهد حموي2024-02-19 22:41
I switched to 225/55/17 run-flat tires, and the handling is pretty good.
20
حسين باسل
حسين باسل2024-02-19 20:41
Continental is definitely good.
I'm getting ready to order a car. How much should I negotiate for a discount, guys, so I have a reference?
Hey guys, isn't the 2019 Changan Yuexiang's wheel 14 inches? The tires are 175/65/R14. I'm thinking about changing the tires. What's the maximum size I can switch to? Thanks.
Why does the specification on my tire sidewall say 215/50/17 instead of 205/50/16? The current tires on the wheels are 215/55/17. It's a 2016 automatic comfort model produced in 2019.
Is it possible to change the tires to 215/60 R17? The 55 ones seem a bit small.
Looking for advice on changing tire and wheel sizes. The original Sahara comes with 245/75/17 ET+44. Considering two options for new wheels and tires: Option A: 265/70/17 ET+18 9J, where the tire is flush with the fender. Option B: 265/70/17 ET 0 8.5J, where the tire slightly protrudes beyond the fender. Which option is better in terms of performance and safety?
If you want to modify your tires without changing the 17-inch diameter, you can consider changing the tire's width or profile. You can opt for a wider tire for better grip or a different profile for improved performance. Just make sure the new tires fit your vehicle's specifications and don't affect the overall driving experience. It's always a good idea to consult with a professional or refer to your vehicle's manual for recommendations.
I've been driving a Peugeot 307 for over ten years and I'm ready to change cars. However, I feel like it's hard to find a car in the same price range that matches its safety, stability, and handling. Does anyone have any recommendations?
Has anyone here modified their car or changed tires? My left front tire got a nail in it and can't be repaired. I've been asking around but can't find a Toyo 225 55 R19 tire, and with the national holiday, I can't replace it until the 4th. It's really inconvenient. Has anyone switched to other tire brands after buying their car? Any recommendations? I'm hesitant to replace just one tire with a different brand, and since I need the car urgently, I'm considering replacing both front tires.
Is there a significant difference between the 17, 18, and 19 models of T3 and T4? Can an expert help clarify this?
