I bought a 280 Sharan in October 2017, and it has run 38,000 km. Recently, I've noticed that the car stalls and restarts twice when auto start-stop is active. It happens when I stop at a red light; the car auto-stops, then restarts, and soon after, it auto-stops again and immediately restarts. This doesn't happen very often, only twice this month, and otherwise, the car runs fine. Can anyone advise on what might be the issue? Should I take it to the dealership for a check-up?
Comments( 7 )
The auto start-stop function on my 2020 model 280 Comfort version has been inactive for a month. No matter how I park, it won't activate. What could be the issue?
Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
4How do I turn off the auto start-stop on the ILX? 😅
5The Kia Sportage automatic stalled while adjusting the air conditioning in D gear at idle. It restarted successfully and has only happened once, otherwise everything is normal.
6Does the 2021 Fengxing T5 EVO have an auto start-stop feature? It seems like it doesn't, but I'm not sure. I need to change the battery, but I'm not sure if it has the auto start-stop function.
7How do I disable the auto start-stop feature on the 2015 Subaru Outback?
8After replacing the battery in the 2019 Ford Territory, the auto start-stop feature is always on unless manually turned off. What's happening?
9The EPC light came on twice, but restarting the engine fixed it, and it hasn't appeared again. Fellow car enthusiasts, what could most likely be the issue?
10When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
