How to fix the issue of the right rear door of Volkswagen Sharan bouncing back when closing?
Sometimes, the middle door of my car closes halfway and then bounces back. Does anyone know why this happens?
I bought a Kia Sportage in 2010, and suddenly the right rear door won't open. What could be the reason? It's not the child lock issue. Also, the door handle feels loose when pulled.
4Hasn't anyone mentioned the noise issues with this car? In summer, there's some noise from the right rear door area, and in winter, it's from the right front.
5What could be the issue with the right rear door of a Jetour X70 not locking?
6Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
7What could be the issue with the electric sliding door of my Volkswagen Sharan not fully opening or closing?
8Why do I feel that the soft-closing mechanism on the rear door is less sensitive than the front door? With the same amount of force, the rear door doesn't close properly. Do you guys experience this too?
9The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
10Is it true that you can't open the right middle door when opening the fuel tank cover on the Sharan 2.0 standard model?
