عبدالله ميك
2024-10-02 11:49
Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
حسين صلاح
حسين صلاح2024-10-28 18:17
It's hard to tell if the compressor is running or not.
20
What could be the issue if the air conditioning compressor keeps running even when the AC switch is properly turned off? Does anyone know?
The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
Is it normal for the fan of a 2015 Sharan with 150,000 km to keep running at high speed after turning off the engine and removing the key, especially after driving 30 km with the AC on? The current outside temperature is 39 degrees. Looking for advice from fellow car enthusiasts.
When you start your 2019 model car and turn on the AC for the first time, you hear a noise like the fan suddenly stopping. What's causing this? It only happens once and then works normally afterwards.
Today, I went to the 4S shop to change the oil. When the car was lifted, I tried spinning one of the rear wheels by hand, but the other rear wheel didn't move. For a four-wheel drive, shouldn't turning one wheel cause the other to spin in the opposite direction, like the front wheels do? Can someone explain if this is normal?
Hey guys, why does the AC sometimes turn on by itself after starting the car? I usually don't forget to turn it off.
Hey car enthusiasts, how's your AC performing? I turned it on today and it didn't feel that cool. At 11 am, it was cooler with the windows down.
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
