عبد العزيز جليل
2024-01-27 09:25
Hey folks, when my Sharan goes over bumps, I often hear a noise coming from the doors or the back seat. Does anyone know what might be causing this? Can the door gaps be adjusted? If so, how do you adjust them? Looking for some advice. Thanks!
علي اشرف
علي اشرف2024-02-02 14:24
Hi everyone, Sharan friends: Is the 1.4T really enough?
حسن حرب
حسن حرب2024-01-27 12:42
It's not worth spending too much. As long as it drives, it's fine. I'll buy a Multivan when I have the money.
I've got a 2012 XV and while driving, the hill assist light turns on, then goes off, and comes back on again. Does anyone know what might be causing this? Has any fellow driver experienced this and how did you resolve it?
Hey folks, how do people usually play with these supercars? Besides showing off in the city and taking girls for a ride, do people often go mountain driving or hit the track with them?
Hi everyone, I've been having issues with my Hongqi H7 where the side mirrors often don't fold when I lock the car and the seat adjustment occasionally fails too. I noticed these problems tend to occur together. I had the wiring checked and charged the battery, which fixed it for a while, but then it started happening again. I thought it might be the battery losing charge, so I replaced it. It was fine at first, but then the problems came back. The mirrors fold manually without any issues inside the car; it's just when I lock the car that they don't fold, and the seat adjustment also fails!
Noise issue, seeking advice from experts. I have a 2020 1.6 manual ASX. When driving on highways or national roads, once I go over 100 km/h, there's a knocking sound from the back after a bump, like a board isn't fixed properly. Yesterday, it was really annoying while on the national road. Even after stopping the car and restarting it, the knocking sound was still there. When I got home and tested it again, it was gone. This has been happening for a while, and I've checked multiple times but couldn't find the cause. Considering yesterday's situation, I suspect it might be an exhaust pipe issue. Has any fellow car owner experienced a similar problem?
I have a 2017 automatic model with 50,000 kilometers on it. Recently, I've noticed three particularly obvious issues: 1. When starting at traffic lights, even with light acceleration, I can hear the engine howling. The fuel consumption spikes to 19.9, the engine revs up to 2000 RPM, but the acceleration is very slow. 2. When driving home from work and going up the parking ramp, I often find that even with the gas pedal pressed, there's no power. The RPM goes up to 3000, and the fuel consumption also spikes. 3. Occasionally, when starting the car, it will shake and then stall by itself. Overall, driving at speeds between 0-40 is uncomfortable, but things improve above 60, especially on the highway. Acceleration and overtaking are fine at higher speeds. It's quite frustrating. Is anyone else experiencing the same issues?
Sudden braking causes noticeable bumps, and you can hear the fuel sloshing in the tank.
It's normal for the idle speed to fluctuate when you turn on the air conditioning in a 2013 1.6 manual fashion model. Sometimes the RPM might go up to around 900 or almost 1000, and other times it might be around 800. If you restart the engine and the RPM goes back to around 800, it's usually not a cause for concern.
How do I adjust the gap between my car doors if it has become larger?
There's a bug in the fuel consumption mileage stats of the Nissan X-Trail EP, which causes it to reset automatically. This has happened a few times, and each time all the data on the "Since Last Refuel" page gets cleared. I'm not sure if it's a bug. It's still hard to pinpoint the exact conditions for the issue to reoccur, but I can confirm it should include the following: 1. Long periods of idling without turning off the engine 2. Unlocking the car doors 3. Leaving the car with the key (out of sensing range) Then, when you return, you'll find the data has reset. This has happened three times, and looking back, it was pretty much under these circumstances.
