حسين ابراهيم
2024-06-03 10:23
Hey folks, the touchscreen on my Sharan sometimes doesn't respond well, and the circulation button also occasionally acts up. Any ideas on what's going on? Looking for some advice!
منصور عبدالرحمن
منصور عبدالرحمن2024-06-04 06:57
Just replacing the film is enough, 39 bucks.
2
The check engine light is on, indicating an engine emission fault, but the DPF regeneration indicator is not lit. Holding the regeneration button doesn't work, and sometimes the vehicle doesn't accelerate properly. What could be the reason for this? Any ideas, everyone?
The fan on my Sharan sometimes doesn't turn on even when the temperature is high. What could be the reason? Any advice?
Hey folks, the car is uneven on one side, the driver's side is 3cm lower. I've replaced all the springs and shock absorbers, and also changed all the chassis bushings, but it's still the same. The driver's side leans heavily when turning. Can any experts offer some advice?
My 2013 Sharan's electric door sometimes won't close by itself, and the button doesn't work either. After disconnecting and reconnecting the power, it works again. Does anyone know the reason?
Hey folks, when my Sharan goes over bumps, I often hear a noise coming from the doors or the back seat. Does anyone know what might be causing this? Can the door gaps be adjusted? If so, how do you adjust them? Looking for some advice. Thanks!
Hi everyone, I need some advice. The middle doors on my T6 keep having issues. Sometimes they automatically open or close halfway and then suddenly bounce back. Other times the button doesn't work at all, and the door button flashes a fault. Sometimes I have to press the button twice, holding it down on the second press until the door fully opens or closes before I can release it. What could be the problem, and how should I fix it? Please help.
How do I reset the trip meter on a 2016 V60CC? I watched a video yesterday that said to press the "O" button on the steering wheel control, and it worked yesterday. But today, it doesn't respond. Any advice?
Hey buddies, does anyone have a rattling noise from the passenger side dashboard? My car is from 2021 and has less than 60,000 km. It happens when I turn on the power, while driving, and sometimes even when it's off. The noise also appears when I turn on the AC and occasionally when using the wipers.
Hey folks, when starting the car cold and switching from P to D, the transmission makes a clunking sound. Also, when parking and switching from D to P, the car lurches forward a bit. Any idea what's causing this?
