Hello fellow car enthusiasts! Why is the reverse camera on my 2013 Sharan 2.0T showing the left and right sides reversed?
Hello fellow car enthusiasts, I just bought a Navara. I noticed that the reverse camera image shows things a bit farther away, but in reality, they're much closer. Is there a way to adjust it to appear closer? I'm not quite used to it!
Hi fellow car enthusiasts, how do you reset the tire pressure? The front right wheel keeps showing an error.
Is the fog light above the taillight on the left side only and not on the right side for the Sienna Platinum version?
4Does the 2012 Sportage GLS have a reverse camera? Sometimes when I reverse, it shows "searching for signal," and other times the central screen doesn't change.
5Hello fellow car enthusiasts, I'm interested in a 2013 Touran with an EA111 engine. Does this engine consume oil? Does it have a lot of minor issues?
6Can I plug a home charger into the fast-charging port on the left side, considering that my parking space has more room on the left and the right side is against the wall?
7I'm looking to install a central control screen with a reverse camera on my 2014 Peugeot 301. Any recommendations, fellow car enthusiasts?
8Hello fellow car enthusiasts! Why is the reverse camera on my 2013 Sharan 2.0T showing the left and right sides reversed?
9Hello fellow car enthusiasts, my car makes a thumping noise from the right front wheel when I turn left. Does anyone know the reason for this?
10Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
