مكرم حسين
2023-05-12 22:28
Has anyone experienced the voice control button on the steering wheel not working, and being unable to make calls after connecting the phone via Bluetooth? The repair shop's computer test shows a microphone fault code. How can I fix this? Thanks, experts!
The check engine light is on for your 2010 Mazda3 hatchback, and the fault code indicates that the fuel trim system is too lean after the catalytic converter. Here's what you can do: 1. **Check for Vacuum Leaks**: Inspect hoses and connections for any leaks that might be causing the issue. 2. **Inspect the Oxygen Sensors**: A faulty oxygen sensor can lead to incorrect fuel mixture readings and should be checked. 3. **Examine the MAF Sensor**: The Mass Air Flow sensor might be dirty or malfunctioning, affecting the air-fuel ratio. 4. **Look at the Fuel System**: Check the fuel injectors and fuel pressure to ensure they are functioning properly. 5. **Check the Catalytic Converter**: Although less common, a failing catalytic converter can cause similar issues. 6. **Professional Diagnosis**: If you're unable to identify the problem, it may be best to consult a professional mechanic for a thorough diagnosis. Remember, addressing the issue promptly can prevent further engine damage.
When playing music via Bluetooth, I can't hear sound from WeChat voice messages and phone videos. How can I fix this?
There is a buzzing noise while the vehicle is in motion, but I'm not sure where it's coming from. The mechanic thinks it's too much trouble to check and says it's fine as long as there are no fault codes in the car's computer.
In the 2019 JETOUR X90 Enjoy Edition 6-seater with a 6DCT dry dual-clutch transmission, currently at 120,000 kilometers, an issue has been occurring since around 90,000 kilometers. When starting the car cold, everything is normal during acceleration. However, after driving for about half an hour and the engine warms up, when stopping or waiting at a traffic light and then trying to accelerate again, the car doesn't respond to the throttle. If you press the throttle harder, the engine stalls. When you feel the engine shake while pressing the throttle, if you release the pedal immediately and then press it again, the car can start moving, and everything works normally after that. There are no fault codes detected by the computer, and the spark plugs have been replaced. The engine checks out normal at the 4S shop. I'm seeking advice from experts on how to resolve this issue or if any fellow JETOUR X90 owners have experienced a similar problem and how they got it fixed. Thank you very much for your help!
