Does anyone know if the center console screen frame panel of the 2016 model is the same as the 2012 model? I only found the panel for the 2012 model, the one with the air vents.
The center console screen of the 2017 Renault Koleos is not turning on. The 4S shop says the main unit is broken. How much does it cost to replace the main unit?
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
Can the 2007 model's center console be upgraded to the 2012 model?
4How to turn on the center console screen of the Haima S5 if it's not lighting up?
5Does anyone know if the center console screen frame panel of the 2016 model is the same as the 2012 model? I only found the panel for the 2012 model, the one with the air vents.
6Does anyone know where to replace the cigarette lighter fuse with a key symbol under the center console of the 2016 Grand Cherokee mechanical gear model?
7The air conditioning in my 2019 model Yueshang only blows air towards the front windshield, while there's no air coming from the center console or side vents. Does anyone know what might be causing this issue, and is it complicated to repair?
8Can the center console of the 2016-2017 model be modified or upgraded?
9How to Replace the Center Console Screen
10Is anyone else experiencing an issue with the footwell air vent on the Aion? Even after turning off the footwell vent on the control panel, cold air still blows on my ankles. It's really uncomfortable on a long drive. Anyone else having this problem?
