Did anyone else receive a recall notice recently for the 280 regarding the fuel rail bolts issue? The recall is starting at the end of February.
Hey everyone, I recently noticed a rustling noise near the B-pillar on the passenger side when driving over bumpy roads. I've had the car for a year, but this just started happening. It doesn't make noise on regular bumpy roads, only when the car sways side to side. I've tried fastening the seatbelt and applying grease to the buckle, but the noise persists. Has anyone else experienced this? Any suggestions on how to fix it?
My car is automatic, and I recently noticed that when I start on an uphill, there's a kind of "bo bo" sound when I press the gas. It seems like it's coming from the transmission. But when I'm driving normally, there's no problem. Even when I hit the gas hard or drive on the highway, it's fine. It's just when I start on an uphill. 😂
4Is there a delay when starting the Renault Koleos 2019 model in cold weather? Has anyone else experienced this, and how did you solve it?
5I'm driving a 2017 model 1.4T automatic 2WD luxury version. Last year, I replaced the recalled vacuum pump. When I used to drive it daily, I didn't notice any issues. Recently, I've been using the car less, and after it's been parked for a day or two, the brakes feel hard when I start it in the morning. I wanted to check if the vacuum is sufficient, so I tried coasting in neutral and after pressing the brakes a couple of times, they become hard. I want to ask fellow car owners if they've experienced the same situation. Thanks.
6Recently, I noticed that the two apps installed by the dealership when I bought my car, Changan Auto and Zhihui Cloud Control, have the same content. Has anyone else experienced this? [Facepalm]
7Help Needed: 2011 Nissan Sunny Low-End to High-End Instrument Panel Upgrade Issue At first: As shown in the picture, I bought a 2012 luxury version of the Sunny instrument panel. I removed the wires from the low-end panel and connected them according to the high-end socket order. Because I enlarged the wire holes when removing them, it led to poor contact. Initially, everything was normal except the fuel gauge didn't display. Could it be due to poor contact? Then, I reconnected the original low-end instrument panel, which led to the time, trip mileage, and fuel consumption resetting every time I started the car. Finally, I got another high-end socket. This time, I arranged the wire order for the high-end socket first, then connected wires from the low-end socket to the high-end socket (this method avoids enlarging the socket and causing poor contact). Now I'm stuck with the following issues: 1. The engine light is on. 2. The turn signal, headlight, and fog light indicators on the instrument panel don't light up, and there's no ticking sound when using the turn signal. 3. Each time I start the car, the time, average fuel consumption, and trip mileage reset. 4. After turning off the car, the tachometer stays at 1, then drops to 0 and returns to 1 when the car is started again, which seems normal. Everything else seems normal. Could fellow forum members help analyze what the problem might be? I'm almost crying.
8Hello fellow car enthusiasts! I bought my ZS at the end of 2019, and it has driven over 120,000 kilometers so far. Recently, it started showing a fault code indicating that the catalytic converter efficiency is below threshold. Has anyone else replaced their catalytic converter? What was your experience? Thanks!
9I have a 2020 Touareg 3.0, and recently I've noticed that the 360-degree camera is getting less clear. Does anyone else experience this?
10I recently got a CX-5 less than a month ago, and I noticed that when starting the car cold and shifting to D gear, there's a noticeable "jerking" sensation as the car moves forward. After driving for a while and the car warms up, when switching between N and D gear, the jerking sensation is still there but much less noticeable. Is this normal?
