"The electronic shift backup has been activated; please service soon." This message indicates that there might be an issue with the electronic gear shifting system in your vehicle. It's recommended to have it checked and serviced by a professional as soon as possible to avoid potential problems.
The 4WD high indicator light on the Jimny is flashing. Does that mean it's engaged or not?
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
4Recently, my engine light came on. I went to the shop to reset it, but it came back on, indicating "Please check the emission system." Can any expert advise?
5The check engine light is on, indicating an engine emission fault, but the DPF regeneration indicator is not lit. Holding the regeneration button doesn't work, and sometimes the vehicle doesn't accelerate properly. What could be the reason for this? Any ideas, everyone?
6How to connect Bluetooth on Jeep Compass, step-by-step: 1. Turn on the Jeep Compass and ensure that your Bluetooth device is also turned on and discoverable. 2. On the vehicle's infotainment system, navigate to the Bluetooth settings menu. This is usually found under "Settings" or "Phone" options. 3. Select "Add Device" or "Pair New Device" from the Bluetooth menu. 4. On your Bluetooth device (like a smartphone), go to the Bluetooth settings and search for new devices. 5. When you see "Jeep Compass" or a similar name appear in the list of available devices, select it to initiate the pairing process. 6. A confirmation code might appear on both the infotainment screen and your device. Ensure the codes match and confirm the pairing on both the vehicle and your device. 7. Once paired, your device should connect automatically whenever you start the vehicle in the future, as long as Bluetooth is enabled on your device. If you encounter issues, make sure both the vehicle and device have the latest software updates, and try restarting both if necessary.
7The check engine light on my Nissan Sunny came on, showing fault code P0705-00, which indicates an issue with the transmission range sensor A. The car suddenly jerked, and then the gear indicator on the dashboard disappeared. After turning off the engine and restarting, the gear indicator reappeared, but after a while, the check engine light came on again. I went to a repair shop to clear the fault code, and it seemed fine while driving, but the issue occurred again after some time. This has happened several times. Could it be a problem with the right tail light base?
8Occasionally, the vehicle loses gears while driving, but after restarting, it returns to normal. The repair shop couldn't read any error codes and initially suspects the mechatronic unit might be the issue. Are there any other owners with the same problem? How did you resolve it? Thanks 🙏
94WD light is flashing, and the vehicle won't start.
10To reset the tire pressure light on the MG GS 4WD, follow these steps: 1. **Check Tire Pressure**: Ensure all tires are inflated to the recommended pressure levels. You can usually find the recommended pressure on a sticker inside the driver's door or in the owner's manual. 2. **Drive the Car**: Sometimes, simply driving the car for a few miles can reset the tire pressure monitoring system (TPMS) if the tires are properly inflated. 3. **TPMS Reset Button**: Some models may have a TPMS reset button. Check your vehicle's manual for its location and instructions on how to use it. 4. **Professional Assistance**: If the light remains on, it might be necessary to have the system checked by a professional, as there could be an issue with the TPMS sensors. Please follow these instructions based on your specific vehicle model and refer to your owner's manual for more detailed guidance.
