عبدالرحمن شاكر
2024-01-01 10:12
The fuel consumption unit for the Comfort Edition of Sienna is displayed as km/L, and it cannot be changed to L/100km on both the steering wheel and the main screen.
Hello! How can I connect the multifunction steering wheel buttons of the Tuluozhe E7 with the car's display screen?
The center console screen of the 2017 Renault Koleos is not turning on. The 4S shop says the main unit is broken. How much does it cost to replace the main unit?
Is there a way to change the fuel consumption display from km/L to L/100km on both the dashboard and the main screen?
I currently drive an eight-year-old Nissan Sunny 1.5 with a fuel consumption of 6.5 L/100km and have driven 50,000 km. I have a parking space at home where I can install a charging station, and I don't drive much on highways. Is it necessary to switch to an electric car? My main considerations are saving money and having shelter from the elements. I don't drive the petrol car much because I don't need to and the fuel is expensive, so I prefer using an electric bike. It would be different if I switch to an electric car, right? What car would you recommend?
Fellow car enthusiasts, my GS5's central control screen keeps rebooting. The 4S shop said the main unit is broken and it would cost 6k to replace it. [Facepalm] Has anyone else encountered the same issue? Is it possible to repair it?
I'm sincerely looking to buy a used Taycan, 2021 model with less than 40,000 km. Preferably in white. Both Shanghai plates and non-local plates are fine. Ideally, the interior should have red and black, with Bose loudspeakers, electric sound system, and display screens. Budget is 500,000 RMB.
The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
Why is the Baidu CarLife in the 2023 Jetour X90 Plus Villa edition only displaying on half the screen?
McLaren McLaren Senna
McLaren SennaAED 4,580,000 ~ 5,000,000Gasoline & Petrol
