ابراهيم خالد
2024-07-26 14:17
Will running the air conditioner on a Kia Seltos for 2 hours while stationary damage the car? I've heard that the manual says idling is bad for the car?
علي جلال الدين
علي جلال الدين2024-07-27 06:30
Idling for 2 hours isn't really good; it can lead to carbon buildup.
Is there a significant difference in driving experience between the 2.5 and 3.0? I'm planning to buy a used Viano and later get a towed RV. Will a 2.5 engine struggle with towing a trailer? Normally, the 2.5 should consume more fuel compared to the 3.0, but since the car often idles for 1-2 hours waiting for people, would the 2.5 be more fuel-efficient in this situation?
If the car wasn't completely stopped before shifting into reverse and you heard a grinding noise, it could potentially cause damage. It's generally recommended to ensure the vehicle is fully stationary before changing gears to avoid any harm to the transmission system.
Hey fellow car enthusiasts, I've heard that the T8's engine noise inside the car is quite loud when it's running. How bad is it, and is it tolerable?
I have an HS7 at home. I'm considering buying a new energy SUV. I don't go out often, but when I do, it's usually a long trip (at least 2 hours). My friends have recommended brands like Li Auto, NIO, and AITO, but I'm thinking about the HS9. However, I've heard it doesn't have a good reputation. I'm here to seek advice on the following aspects and would appreciate genuine feedback and evaluations: charging speed, charging pile installation, material quality, human-vehicle interaction, intelligence, maintenance, and actual range. Thank you, everyone.
I've heard that the car's infotainment system is quite bad. Does it have a Sentry Mode? Carbon fiber repairs are so expensive, I really hope it can catch hit-and-runs.
Kia Kia Seltos
Kia SeltosAED 85,571 ~ 110,500Gasoline
