Why isn't the left side of the lights on my Kia Cerato working when I lock the car? Is it a blown fuse or a burnt-out bulb?
The loudspeaker on the driver's side isn't working, how do I take it out? Any tips, experts? 💡
Who has a complete picture of the engine bay fuse box? Mine is not clear, and I think the headlight fuse is blown. It's not working, urgent!
If the unlock or lock light is not working, how to fix it?
4Why do the brake lights look different on the left and right, and why is the left light not working?
5Left reverse light not working?
6Is the fog light above the taillight on the left side only and not on the right side for the Sienna Platinum version?
7To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
8Friends, with your Taurus side mirrors, is it possible that the mirror is burnt out in this situation?
9Why isn't the left side of the lights on my Kia Cerato working when I lock the car? Is it a blown fuse or a burnt-out bulb?
10Is the left front and rear lock lights of the Kia Cerato not working because the bulb is broken, or is it a blown fuse? Does anyone know?
