Where do you power your dashcam from? If you don't need parking monitoring, is it better to take power from the reading light, OBD, or the fuse box?
It would be great if such a good car had a dashcam with parking monitoring.
Are there any fellow car owners who have installed a dashcam? I bought one, but the 4S shop said they don't know how to install it. Just wondering, does the BRZ only have the fuse box in the engine compartment? How do you all get the power?
11-year manual transmission, car powers on but won't start. Any experts here to help? 😊 Checked the fuse box too. 😢
4The cigarette lighter fuse for the 1819 model of Yuxiang is located in the fuse box. You can usually find the fuse box under the dashboard on the driver's side or in the engine compartment. Please refer to the vehicle's manual for the exact location and diagram of the fuse box.
5How do you guys install your dashcams? Is there a power outlet reserved near the car's rear-view mirror?
6Why is there a buzzing sound coming from the fuse box and then the headlights turn on and the wipers work by themselves?
7How to power the Polestar 2 dashcam, how to get power from the roof light, and are there any recommended dedicated wiring plugs? Are there any good dashcams to use?
8To check the fuse for the front left low beam on a Skoda, you should first refer to your vehicle's owner's manual. The manual typically contains a diagram showing the location of the fuse box and details about each fuse. In most Skoda models, the fuse box is usually located either under the dashboard on the driver's side or in the engine compartment. Once you locate the fuse box, look for the diagram that indicates which fuse corresponds to the low beam lights. Make sure to replace any blown fuse with one of the same amperage.
9Where do you power your dashcam from? If you don't need parking monitoring, is it better to take power from the reading light, OBD, or the fuse box?
10Hi everyone, does anyone know if the dashcam that comes with the JETOUR 24x90PLUS manual model can be upgraded for parking monitoring?
