When using the navigation system in the Seetus, does a large Baidu logo appear? Previously, on the KX3, half of the screen showed the logo, and it was originally CarLife 2.0.
I installed a new large-screen navigation system today, and after installation, the center differential lock light is on, the engine warning light is on, and the traction control light is on. What's going on? Help!!?
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
42008 Suzuki Swift, 1.3L, automatic, 100,000 km, original catalytic converter, large screen navigation, reverse camera, modified headlights. Priced at 11,000. Is it expensive?
5Is this not-so-large vertical screen convenient for navigation?
6When connecting Cyrus to Baidu CarLife, the navigation voice is too low, and the radio volume is too loud, making it hard to hear. How can I increase the navigation volume? The volume button doesn't seem to help.
7When using the navigation system in the Seetus, does a large Baidu logo appear? Previously, on the KX3, half of the screen showed the logo, and it was originally CarLife 2.0.
821 Dark Special Edition, original paint, green, registered in October 2021. Comes with imported Rollypus invisible car film (worth around 30,000). Mileage is 17,000 kilometers, no off-road history, regularly maintained, excellent condition. How much can it sell for? The 21 version has the highest configuration, with a large screen, electric suction doors, and nothing has been downgraded.
9Why is the Baidu CarLife in the 2023 Jetour X90 Plus Villa edition only displaying on half the screen?
