To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
When you start your 2019 model car and turn on the AC for the first time, you hear a noise like the fan suddenly stopping. What's causing this? It only happens once and then works normally afterwards.
To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
In your 2019 GS5, if you want to turn off the colored circle touch assistance on the center console, similar to the assistive touch on an iPhone, you might need to check the vehicle's settings menu. Look for options related to touch or display settings, and there should be an option to disable this feature. If you're not sure, consulting the user manual or contacting your local dealership for guidance might be helpful.
4Is there any modification for the music system of the GA8? Can you recommend a set?
5The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
6The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
7The 2008 model doesn't have automatic air conditioning or physical buttons for the AC, making it hard to adjust to a comfortable setting. Frequently using the screen to adjust can be distracting. Do you have any good solutions for this? Also, it's been raining a lot recently, causing more fogging. Turning on the defogger feels like hot air, and when you turn it off, you need to adjust the AC again. 🤔
8After the central control was reset to factory settings, it shows that it can't connect to the network and can't enter the system.
9To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
10Dear friends, can the 2023 CS35P's auto-hold function be set to turn on automatically? Or do you have to press it manually each time?
