عبدالله عزيز
2024-07-03 12:55
The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
عبدالله فارس
عبدالله فارس2024-07-03 23:32
The door is not closed properly.
Why does the keyless entry only lock but not unlock the car?
If the unlock or lock light is not working, how to fix it?
I reset the central control screen to factory settings. Now, the keyless entry can only lock but not unlock. How do I set it up? There is power! It seems to be protected. How do I unlock the system?
The dashboard always switches to miles automatically. Sometimes the wiper gets stuck when pressed once, then resets after pressing again, and only wipes once after another press. When enabling the lock car beep, the keyless entry is overly sensitive, resulting in a series of beeps. 😔 Does anyone else have the same issues?
I want to ask about the 2013 model, how to disable the horn sound when unlocking and locking the car?
2020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
The keyless entry function on the GS 5 is not working properly. Approaching the vehicle no longer locks or unlocks it, and the function is unresponsive. The key fob's battery was just replaced. What's going on here?
After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
My car has keyless entry, but after unlocking, the car gives four alarm sounds. What's going on? This didn't happen before. It used to just unlock automatically when I got close, with the lights flashing but no sound. Now it flashes four times and gives four alarm sounds!
Kia Kia Seltos
Kia SeltosAED 85,571 ~ 110,500Gasoline
