هشام خالد
Nov 24
Is the premium 360 model only manually activated? How do you set it to start with speed?
How do I activate the Hill Descent Control on the 2019 LTD model?
Can the S40 be set to fold the mirrors when locked? How do you set it up?
How do you activate the automatic door lock feature on a 2019 Haima S5 automatic flagship model?
4I reset the central control screen to factory settings. Now, the keyless entry can only lock but not unlock. How do I set it up? There is power! It seems to be protected. How do I unlock the system?
5How to activate CarPlay on the 2017 model?
6How do you activate the automatic parking brake on the 2013 Legacy? It's listed as standard in the specifications.
7How do I set up the compass on the 2014 navigation model? I can't find the setting option. I switched to a big screen 360. Could the change in the central control be causing the compass to malfunction? Please let me know how to set it up.
8I want to ask fellow car enthusiasts! How do you activate the one-touch window lift function on the 2022 model?
9How do you set the lock on the 2013 Trumpchi GS5?
10How to set up 360-degree imaging to display when turning left or right?
