جواد فهد
2024-11-11 16:21
Is the engine of the Citus equipped with a timing chain or a belt?
The Iveco Daily 3.0 engine uses a timing chain.
Is the 2013 automatic Kia Sportage equipped with a timing belt or a timing chain?
Does the Mazda 5 use a timing chain or a belt?
4Is the timing on the 2017 1.4T Jeep Renegade a chain or a belt?
5The Toyota Yizhi 1.8-liter engine uses a timing chain.
6Is the 2013 model using a timing belt or a chain?
7Will the timing chain of the 2017 automatic luxury version engine stretch?
8The engine in the Iveco Ousheng 2.0 uses a timing chain.
9Has anyone replaced the high-pressure fuel pump and timing chain on a 1.6L engine?
10Is the transmission in the 2019 Murano using a steel belt or a steel chain?
