ابراهيم خالد
2024-07-28 13:16
I've had my Cyrus for just over two months, and the main switch for the window lifter seems to be malfunctioning. When I press it down, the other windows can still move freely. Has anyone else experienced this issue? 😊
I got my car at the end of last year, and now every month there's always a day or two when the windows automatically roll down without any warning. Has anyone else experienced this? I went to the 4S shop, but they couldn't find any issues. [Cool]
Why does my car window go down but not come back up, and I have to press the unlock button repeatedly to open it? [Facepalm]
Hey everyone, I've got an issue with my new Beidouxing. When I slow down, it just stops moving even though the engine is still running. The gear lever feels loose, and I can't accelerate. The power windows should go down gradually, but instead, they drop all the way down uncontrollably. The mechanic couldn't figure it out either. Could anyone help analyze what's wrong? Thanks!
The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
Are there any owners of 2019 two-wheel drive or four-wheel drive luxury models here? I have a question. For models where only the driver's window has the one-touch up/down feature, can you long-press the lock button on the key to raise the windows? Can this be upgraded at the dealership? My 2019 four-wheel drive luxury model can only close the sunroof with the key, not the windows.
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
I'm not sure what you pressed, but now the rear windows only go halfway down. 😢😢😢😢😢
The fuel tank switch is pressed down and won't pop back up. How should I handle this?
The front windows of the Jetour X70 cannot be opened, and the horn alarms when the car is locked with the remote. When the unlock button on the remote is pressed and held, only the rear windows open, while the front windows do not respond. I had this issue repaired at the 4S shop before, and they said it was related to the fuse. However, the problem has occurred again just two to three months after the repair.
Kia Kia Seltos
Kia SeltosAED 85,571 ~ 110,500Gasoline
