حسن نور الله
2024-08-14 13:00
I feel like the reversing camera image is not clear. Can I replace the camera individually?
خديجة سلمان
خديجة سلمان2024-09-10 20:52
Upgrade to a high-end head unit, the high-end is clearer.
I've upgraded my 2009 Scirocco with the 187b head unit, but the reverse camera doesn't switch the screen when reversing, although the radar works fine. Interestingly, the reverse camera works normally when the car is off, but not when the engine is running. I've already replaced the head unit and the reverse camera, but the issue persists. Any experts out there who can help?
Why do I feel like I can hardly see when reversing at night? Is it because I changed to strobe lights? Can any experts help me out? Thanks!
I'm looking for advice from everyone. I want to install a reversing camera on my Mazda 2 and replace the original center console. I'm not sure if the reversing camera center console screens available online are reliable. Do you have any good recommendations?
Hello fellow car enthusiasts, I just bought a Navara. I noticed that the reverse camera image shows things a bit farther away, but in reality, they're much closer. Is there a way to adjust it to appear closer? I'm not quite used to it!
Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
Have you encountered a situation where the reverse camera image is missing the borders and only the image is displayed? How can it be restored to normal?
How can I replace the central screen? Any recommended solutions? I use an Apple phone and hope to use CarPlay. Also, if I replace the central screen, will I lose the reverse camera function?
Today when I was reversing, the reverse camera suddenly showed nothing, and the screen started flickering. What's the problem here? Can anyone help me fix this?
Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
Kia Kia Seltos
Kia SeltosAED 85,571 ~ 110,500Gasoline
