سعود شجاع
2024-09-12 08:28
How do I shift gears when driving a Setus down a long slope?
عبد العزيز منذر
عبد العزيز منذر2024-10-03 22:18
The onboard computer will automatically control the vehicle speed.
عبدالرحمن اميره
عبدالرحمن اميره2024-09-28 13:02
Use the paddle shifters to downshift instead of holding the brake for a long time. The paddle shifters are located below the 3 o'clock and 9 o'clock positions on the steering wheel.
فهد ذكي
فهد ذكي2024-09-13 12:41
Use paddle shifters.
جواد فهد
جواد فهد2024-09-12 17:08
Switching to sport mode gives a significant boost, and you'll need to give it some gas even for small inclines.
سعود سامر
سعود سامر2024-09-12 14:07
Driving in D gear all the time and constantly holding the brake is not recommended. It's dangerous.
The gear lever on this company car is problematic. After shifting to reverse, the detent stays in the engaged position even when you return it to neutral. You have to push it down to disengage. I didn't pay attention today, and when coasting downhill while pressing the clutch, I directly shifted to first gear without pushing the detent down. As a result, the car stalled and now it won't start at all.
How do you guys drive into underground parking lots? I bought a car and realized it scrapes the bottom when I go down. 😢
I want to ask if there is any jerkiness when shifting gears in the GA6.
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
Does the 2024 BYD e2 Automatic Glory Edition have an S gear for descending long slopes?
How do I switch the pointer instrument panel to a digital display on the Setus 1.5 Prestige?
What should I do about the gear shifting impact in the Yuexiang when it's fine when cold but jerks when hot?
What gear do you use when driving up a long incline for an extended period? [Grinning] Share your experiences.
Kia Kia Seltos
Kia SeltosAED 85,571 ~ 110,500Gasoline
