ابراهيم خالد
ابراهيم خالد
Nov 23
Hi friends, after parking my Cyrus luxury edition, there's a clicking sound coming from the driver's area. Does anyone know what might be causing this? Looking for some advice 🙏
أحمد عرفات
أحمد عرفات2024-11-27 17:09
No, mine is also the luxury version.
فهد علياء
فهد علياء2024-11-23 12:43
It seems not. I haven't really paid attention each time I park.
I have a 2012 Jeep Compass. Recently, when I turn on the AC, there's a clicking sound coming from the glove box area, but it stops after a few clicks. Also, when I'm turning at low speeds, it feels like the rear wheels are stuck, causing the car to vibrate and the rear wheels seem to be rubbing or bouncing on the ground. Has anyone experienced similar issues?
I have a 2014 Haima S5 manual transmission, and it's not running smoothly. During acceleration, it feels jerky and there's a noticeable lag when shifting gears. What's causing this issue? Can any experienced drivers or mechanics help me out? 🙏🙏🙏🙏🙏
I bought a 2023 Lavida Star Edition in July. Last week, I accidentally noticed a strange noise around the right rear tire about six minutes after turning off the engine. Friends, do you know what might be causing this?
I just bought a 2018 model 1.0 Passion Edition. Could anyone advise on the best spot to install the parking sensors? Most of the aftermarket sensors need to be at least 50 cm above the ground. The original ones are on the black plastic part and are quite low. So, I'm seeking advice from everyone. Thanks!
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
Hey guys, I seriously need your advice on something. Which one would you recommend between the Mercedes C350eL and the Genesis G80 2WD Luxury version? I haven't really driven much before, so I couldn't really feel the difference in mechanical quality and handling performance during the test drive. I just enjoy listening to music usually, so please help me out! 🙏🙏
Hey fellow car enthusiasts, I've got a 2023 2.0T RuiShang and there's a strange noise when starting up. After starting, there's a "boom" sound after a little while. It happens every time, and it seems to be coming from near the driver's side door, around the left front wheel area. I've taken it to the dealership, but they couldn't find the cause. Has anyone else experienced this?
Hi everyone, I have a 2015 Volkswagen Jetta with a manual transmission. I'm having trouble turning the key in the ignition; it takes several tries and some jiggling to get it to turn. Does anyone know what might be causing this? Any advice would be appreciated. Thanks!
Has anyone used cruise control on the luxury edition? I haven't used it before. I tried it on the highway, but it didn't respond. Am I doing something wrong? Any advice would be appreciated.
Kia Seltos
Kia SeltosEGP 1,177,704 ~ 1,286,180Gasoline & Petrol
