Does Cetus Luxury have a tire pressure display?
Tire pressure warning
Why is the tire pressure warning light still on even though the display shows 220? It's been a week and it hasn't turned off.
Does the Hyundai Accent have a tire pressure monitoring system?
4Does the 2018 Subaru Legacy EyeSight Honor edition have a tire pressure monitoring system?
5How to reset the tire pressure display?
6Have you experienced any issues with the tire pressure sensor?
7The tire pressure is fine, but the tire pressure light came on this time it snowed. What's going on?
8Does Cetus Luxury have a tire pressure display?
9How can I change the display on the left side of the dashboard screen? Mine always shows a car model, but I've seen others display tire pressure.
10Is the Nissan X-Trail EP using a direct or indirect TPMS? If it's direct, after inflating the tires, it doesn't update the tire pressure immediately; it only shows the new pressure data after driving for a while, which seems a bit like the characteristics of ABS estimation. If it's indirect, it can still independently display the pressure of each tire, and the manual also mentions that the tire pressure display might be affected by wireless interference, which sounds more like the working principle of in-tire pressure sensors. So, I'm not quite sure why this TPMS needs to activate at speeds above 25 km/h.
