Can the Setus 1.5 naturally aspirated engine use fully synthetic oil? The mechanic said that even with fully synthetic oil, it should be changed every 5,000 kilometers.
How can I find out which version of the 2020 registered 1.5 naturally aspirated automatic Buick Excelle I bought?
What engine oil is recommended for the Jinxuan 4B11? I've been using the original 5W30 mineral oil from the 4S shop for over 5 years (people say it's like gutter oil [lol]). I want to switch directly to fully synthetic oil. Any recommendations? Some say you should transition with semi-synthetic oil before switching from mineral to fully synthetic. Is this necessary for the Jinxuan?
Does the Peugeot 3008 2.0 naturally aspirated use 5W30 oil?
4For the 2013 model of GAC GS5 with a 2.0L naturally aspirated engine, what type of engine oil do you recommend for maintenance?
5Can a 2017 model 1.5 Fashion Mondeo with 50,000 km in white be exchanged evenly for a 2018 model 1.0 naturally aspirated Smart? 😬😬😬
6Do you use fully synthetic oil or semi-synthetic oil for your 308?
7Is it reliable to convert a naturally aspirated engine to a supercharged one? Is it even legal? I got all excited watching those videos. My little car turning into a 1.5T.
8Which is better for fully synthetic motor oil, Castrol or Mobil?
9Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
10Do you use fully synthetic or semi-synthetic oil for your 10,000 km oil change?
