نايف ضياء
2024-11-27 21:04
Has anyone noticed increased noise sometimes during winter driving in the Seal 2025, when temperatures are around 1 degree? Is it the battery heating system kicking in?
A few questions about the old Levante for the experts here. I bought the Levante as soon as it was released, from the first batch. 1. When in traffic and following at low speeds, the car jerks noticeably. Sometimes when I lightly press the brake and then the accelerator, the car suddenly jerks forward. 2. In cold conditions, the car can't move. It needs to warm up first; otherwise, the accelerator becomes very sensitive and only normalizes once the car is warm. 3. This is the most uncomfortable issue: the steering feels unstable. Especially on ring roads with uneven surfaces due to heavy trucks, the steering wheel moves erratically. I have to hold it firmly with both hands, or it will sway. I would appreciate any expert advice on these issues. Thank you very much!
For a 2011 Volkswagen Phaeton with 130,000 kilometers, experiencing issues with the key frequently failing to unlock the doors or the car not detecting the key inside, along with a loud engine noise, here's what you can do: 1. **Key Issues:** - **Battery Check:** Start by checking and replacing the battery in your key fob, as a weak battery can cause these problems. - **Signal Interference:** Ensure there is no electronic interference around you when using the key. Sometimes other devices can disrupt the signal. - **Reprogramming:** If the issue persists, consider having the key reprogrammed by a professional. 2. **Engine Noise:** - **Oil Level and Quality:** Check the engine oil level and quality. Low or dirty oil can increase engine noise. - **Regular Maintenance:** Ensure regular maintenance is performed, including oil changes and tune-ups, to keep the engine running smoothly. - **Inspect Components:** Have a mechanic inspect the engine components like the timing belt, exhaust system, and other parts that might contribute to the noise. Regular maintenance and addressing minor issues promptly can help maintain the car's performance and longevity.
Why does the right front wheel of my 2019 GA6 get about ten degrees hotter than the other three wheels after driving for a while? When I touch the hub, the temperature difference is quite noticeable.
Does anyone else experience wind coming through the headliner when the AC is on (especially when the fan speed increases)? I can feel a noticeable draft when I touch the driver's side seal. There's also a whistling sound when the windows are closed. Is there a car owners' group? I'd like to join.
Can version 3.1.9 be upgraded? It seems that versions 3.0.3 and 3.1.2 were pulled back just a few days after their release. Version 3.1.10 was just released a couple of days ago and hasn't been pushed out yet. Currently, version 3.1.9 is being pushed in China. In the U.S., 3.1.9 was pushed out in early July, and it has been available in Europe for about a week. According to U.S. car enthusiasts on forums, some vehicles experienced a flickering issue with the 360-degree surround view in versions 3.0.3 and 3.1.2, where the screen would briefly go black and then light up again. After upgrading to 3.1.9, the issue was significantly alleviated during the first week, with flickering still occurring but only going black for 0.2 seconds and then automatically recovering, not affecting usability. However, the results after one week were not satisfactory, with the 360-degree surround view showing more frequent "camera unavailable" warnings than before, still severely affecting use. Yet, some car owners reported never encountering this issue (even with the problematic 3.x versions), so it might be related to a specific batch of parts or the vehicle's personalized settings. Have car owners in China noticed this issue after upgrading, or are there any other problems?
Has anyone with the Ariya tried the single pedal mode with economy? Have you noticed that sometimes when you start, there's no response when you press down, and it takes a few seconds before the power kicks in?
I have a 2022 2.0L Premium model. I've noticed some vibrations during driving, and then there's a strange noise from the trunk. It might be an issue with the seal being too thin. Have other owners experienced this?
