عبدالرحمن ذكي
2023-12-08 21:56
Occasionally, the vehicle loses gears while driving, but after restarting, it returns to normal. The repair shop couldn't read any error codes and initially suspects the mechatronic unit might be the issue. Are there any other owners with the same problem? How did you resolve it? Thanks 🙏
محمد عباد
محمد عباد2023-12-10 10:36
I also have a 2.0T. It's fine in the summer, but this happens in the winter. I haven't fixed it yet. Just getting by for now. Anyone got any advice?
2
My car had a minor collision and was repaired, but the alignment wasn't done. The steering wheel is off-center. After driving for a while, an error code appeared, indicating that the stability control system needs repair. A diagnostic showed that the steering wheel position is incorrect. After clearing the error code, it came back after driving for a while. Can any experts advise on what the issue might be?
Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
I have a 2017 V60, and sometimes I hear a clicking noise from the chassis when driving at high speeds. The noise disappears if I lightly tap the brakes. I suspect it might be an issue with the brake system, but I've been to the dealership twice and they couldn't solve it. Has anyone experienced a similar problem? Any solutions would be greatly appreciated!
Haval H2 automatic fashion 2019 model, when pressing the brake, it automatically shifts to neutral and can't shift back. You need to turn off the power and restart to be able to shift. There's no fault code on the screen. Any fellow car owners experiencing the same issue?
Jeep Liberty, 2012 model with over 170,000 km. It often stalls, especially when reversing with the AC on. When waiting at a red light with the brakes fully pressed and the AC on, it occasionally stalls too. I can't read any error codes. Does anyone know what might be the issue? Could it be a compression problem?
Gear won't engage. Every time this happens, I just turn off the car, wait a bit, then restart, and it goes back to normal. Took it to the repair shop, but they couldn't find any issues.
Hello everyone, I have a question: My Mazda 6 had the engine light and oil light come on after shifting to neutral while waiting at a traffic light. The idle was normal, but there was no response when I pressed the gas pedal and shifted to drive. After restarting the car, everything went back to normal. I went to the dealership, but they couldn't find any error codes. Has anyone experienced something similar? How can I fix it?
I have a Haima S5 with an automatic transmission, and occasionally the transmission warning light turns on. But when I press the brake, it goes off! When I try to read the error code, nothing shows up. What could be the reason?
Volkswagen Volkswagen Scirocco
Volkswagen SciroccoTBDGasoline & Petrol
