عبد العزيز رضوان
2023-09-22 14:43
Is the Scirocco only able to use 95 octane fuel?
نايف تامر2023-10-03 21:24
92 is also okay, but the power isn't great. I don't recommend it. It's still better to use the manufacturer-recommended 95.
عبدالله حرب2023-09-25 23:04
I want to ask which port to add engine coolant. Please don't say it's the windshield washer fluid port or the antifreeze port.
نايف مراد2023-09-23 19:56
98 is also okay. 😁
محمد وحيد2023-09-23 16:00
It's best to use 95. Although I've seen some using 92, 95 is definitely better.
Guys, does the RCZ only require 95 octane fuel?
Can a Nissan GTR use 95 octane gasoline?
Does the 2015 automatic Touran need to use 95-octane fuel?
4Does the 2011 MDX use 92 or 95 octane fuel?
5Is the Scirocco only able to use 95 octane fuel?
6Can using 95-octane fuel provide a power boost for a vehicle like the Kia Sportage that specifies 93-octane (now equivalent to 92-octane)?
7Can I use 95 octane gasoline?
8In 2022, the car required 95 octane fuel, but for the 2024 model, it uses 92 octane fuel. I checked and it seems like nothing has changed. Why is that?
9I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
10Are you using 95 or 98 octane fuel?
