عمر أمين
عمر أمين
Dec 1
I've upgraded my 2009 Scirocco with the 187b head unit, but the reverse camera doesn't switch the screen when reversing, although the radar works fine. Interestingly, the reverse camera works normally when the car is off, but not when the engine is running. I've already replaced the head unit and the reverse camera, but the issue persists. Any experts out there who can help?
نور الدين سعود
نور الدين سعود2024-02-15 22:52
It's estimated that you'll need to use the original factory door handle camera.
أحمد معتصم
أحمد معتصم2024-02-09 04:38
Top!
أحمد معتصم
أحمد معتصم2023-10-21 22:33
Is it resolved?
Does the 2012 Sportage GLS have a reverse camera? Sometimes when I reverse, it shows "searching for signal," and other times the central screen doesn't change.
Has anyone experienced the compass not working after replacing the original head unit? Any solutions?
If you want to add a reversing camera to your 207, you can follow these general steps: 1. **Choose a Compatible Camera**: Make sure the reversing camera is compatible with your Peugeot 207 model. 2. **Purchase Necessary Equipment**: You'll need the camera itself, a compatible monitor, and any necessary wiring or connection kits. 3. **Installation**: - **Mount the Camera**: Usually on the rear license plate area or bumper. - **Run the Wiring**: Connect the camera to the monitor and power source. This often involves routing the wires through the car's interior. - **Connect to Power**: Typically, the camera is powered by the reverse light circuit, so it activates when you shift into reverse. 4. **Testing**: Once installed, test to ensure the camera activates correctly and the image displays on the monitor. If you're not comfortable doing this yourself, it's a good idea to have a professional handle the installation to ensure everything works correctly.
Today when I was reversing, the reverse camera suddenly showed nothing, and the screen started flickering. What's the problem here? Can anyone help me fix this?
The reverse camera is seriously lagging, and the dashcam function isn't working. Does anyone else in the car enthusiast group have the same issue?
The reverse camera frequently goes black, and sometimes it works. How can I fix this? Looking for advice from the experts. 🙏
My 2018 Mitsubishi ASX suddenly has an issue with the multifunction buttons on the steering wheel. When I press the next track button, it switches to the previous track. Pressing the previous track button takes me to navigation or the radio. I replaced the Android head unit three weeks ago, and everything was working fine after the replacement. The issue just started today. I'm not sure if it has anything to do with the new head unit. Does anyone know how to fix this?
Has anyone experienced issues with the radar not working? I recently noticed that when I turn on the radar, it beeps three times, and then there are no distance alerts. Is it broken?
Regarding the issue where the 360-degree camera system doesn't activate when reversing, but works fine when the turn signal is on, how can this be resolved?
Gear position not displayed, a constant line, and the reverse radar is not working.
Volkswagen Scirocco
Volkswagen SciroccoSAR 220,500 ~ 242,550Gasoline
