I recently got a 2013 model 2014 Scirocco GTS. Why does the car start shaking and not move when I floor the gas pedal to start?
4Hey fellow car enthusiasts, when I start my 2014 Scirocco 1.4 and give it a bit more throttle, there's a rattling "dada" noise and the car shakes. What could be causing this and where is it coming from?
5Hey car enthusiasts, I've got a 2014 Scirocco 1.4T. When I give it too much gas while starting, the car makes a rattling sound, like "da da da," and there's a strange noise! Anyone know what might be causing this and where the sound is coming from? Looking for advice from experienced car owners!
6Hey guys, my automatic Kia Sportage isn't moving when I shift into reverse. It only starts backing up when I give it some gas. Any ideas?
7When the car is not started, the brake works, but after starting, the brake pedal goes straight to the floor. What could be the issue?
8Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
9Is your 2015 Jetta also like this, where the RPM only reaches around 3800 when you floor the gas pedal in neutral and doesn't hit 4000?
10I have a 2017 New Santana, and occasionally it won't start. If I wait a while or press the gas pedal, it starts. Can someone explain what's going on?
