فخر دين محمد
2024-10-05 04:56
I'm seeking advice from experienced Scirocco owners. I have a 2012 2.0T Scirocco, and every time I accelerate a bit harder and the RPM goes higher, the EPC warning light comes on. I went to a mechanic before, and they just cleared the code, saying it was nothing serious. But recently, it’s happening more frequently. Can any experienced drivers explain what's going on? Thanks!
سعود حليم
سعود حليم2024-11-29 15:31
Sell it.
عبدالله أسامة
عبدالله أسامة2024-10-10 02:14
Are you referring to the Mazda Atenza and the VW Scirocco? Are you considering buying the Scirocco for fun?
فخر دين محمد
فخر دين محمد2024-10-05 19:44
Thanks, bro! [Thumbs up]
حسين إسحاق
حسين إسحاق2024-10-05 19:34
sensor
I bought the lowest trim of the automatic model. Is there a similar version? I want to ask if the trunk comes with a storage board. My car didn't come with one, and they said only the higher trims have it. Can someone explain this?
When turning on the air conditioning in my 2006 Previa ACR50, I occasionally hear this sound. Can any experts help explain what's happening? Has anyone experienced a similar issue, and what could be the cause? It's a 2.4.
The loudspeakers in my RDX are making a popping sound and sometimes they fail. Previously, there was an occasional popping sound when starting the car cold, but recently it happens every time I start the car. The car's Bluetooth seems to be working fine, and the screen shows that music is playing, but there's no sound. Sometimes restarting the car fixes it, but sometimes it doesn't. This is happening more frequently now. Has anyone else experienced this? What could be the issue?
This car is overall okay, but the manual transmission clutch isn't very user-friendly. I bought my car in 2020, and it's run 23,000 kilometers. In the city, where the clutch is used frequently, it gets harder the more I press it. Do any of you guys have this issue?
Hey car enthusiasts, I've got a 2014 Scirocco 1.4T. When I give it too much gas while starting, the car makes a rattling sound, like "da da da," and there's a strange noise! Anyone know what might be causing this and where the sound is coming from? Looking for advice from experienced car owners!
My Scirocco feels jerky when shifting in S mode. At half throttle, it reaches 4000 RPM and reports an engine fault that needs repair. The EPC light is on, and it mentions something about oil pressure and the engine's maximum speed at 4000 RPM. What's going on, experts? Once I restart the car, everything seems fine (after the car is warmed up, with both water and oil temperatures up to normal levels).
I've been driving a Suzuki SX4 for over ten years, and now the fuel consumption is higher than before. When I press the accelerator, the RPM goes up, but the speed doesn't increase. I've changed the transmission oil, cleared the engine carbon deposits, and worked on the throttle and fuel injectors, but the RPM is still high while acceleration is slow. Are there any fellow car owners who have experienced similar issues?
Hey fellow car enthusiasts, I've switched to Shell Helix Ultra 5W-40 motor oil, but now the acceleration feels sluggish and the idle is higher. Has anyone else experienced the same issue? I was hoping to upgrade to better oil, but it seems to have backfired.
I've been driving my car for six years, and it's covered over 30,000 kilometers. Recently, while driving, the gear indicator on the dashboard disappeared, and the engine warning light came on, but the car was still running fine. I went to a repair shop for a check, and they said there was no problem and cleared the warning light. However, the warning light appeared again soon after, and the gear indicator keeps disappearing intermittently. Additionally, there's shaking when braking to a stop and when starting the vehicle. I'm seeking advice from the community!
Volkswagen Volkswagen Scirocco
Volkswagen SciroccoTBDGasoline & Petrol
