عمر مدرسي
May 2
Hello fellow car enthusiasts, every time I refuel my Scirocco and then put it in Drive, it takes two or three seconds before the car moves forward. Is this normal? If not, what might be the problem?
What could be causing starting difficulties, where sometimes it takes two or three attempts to start?
Hey guys, can the MG GT take up to 60 liters of fuel? Recently, every time I fill up, it's around 52 to 53 liters. Always feels like it's more than before.
Hey car enthusiasts, have you ever experienced a jerky start, where you accelerate but the car doesn't move immediately, and then suddenly jumps forward after a few seconds?
4Hello fellow car enthusiasts, have any of you cleaned the throttle body before? I've heard that cleaning the throttle body on an MG3 is quite a hassle, taking up to 5 hours and costing 500 bucks.
5Gear shifting issue: When the car is cold and I switch from reverse to drive, it rolls back a bit after releasing the brake before moving forward. This doesn't happen when the car is warm. Anyone else experiencing this? It's a 2019 model with 80,000 kilometers on it.
6Hello fellow car enthusiasts, every time I refuel my Scirocco and then put it in Drive, it takes two or three seconds before the car moves forward. Is this normal? If not, what might be the problem?
7Why does it take two or three attempts to start the car?
8I have a 2015 Honda City. Sometimes it takes two or three attempts to start. What's the issue, experts?
9I have a 2023 JETOUR X90 Zilong. When driving at low speeds, if I press the accelerator, the car suddenly surges forward. However, after reaching 70 km/h, if I release the accelerator and then try to accelerate again, there's about a 2-second delay before the car suddenly surges forward. Is this throttle response delay a common issue?
10I'm seeking advice from experienced Scirocco owners. I have a 2012 2.0T Scirocco, and every time I accelerate a bit harder and the RPM goes higher, the EPC warning light comes on. I went to a mechanic before, and they just cleared the code, saying it was nothing serious. But recently, it’s happening more frequently. Can any experienced drivers explain what's going on? Thanks!
