Has anyone here ever replaced a transmission? What issues can get you a warranty for the transmission?
Has anyone ever replaced the rear wheel bearing on Xiaoya?
Has anyone here replaced the charcoal canister?
4For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
5Have you ever experienced occasional jerking with the 2.4 transmission? What could be the issue?
6Has anyone ever encountered an intentional light code?
7Hey fellow car enthusiasts, has anyone ever replaced the humidity sensor in a Grand Cherokee? If this sensor malfunctions, will there be an error code alert or any noticeable issues?
8Has anyone ever changed the hydraulic oil for the chassis lift on an LC100 4700? How do you replace it?
9Has anyone here ever changed the front shock absorber top mount on an Ertiga by themselves? Is it possible to replace the front shock absorber top mount without removing the shock absorber itself? How do you get the top mount off? Any guidance would be appreciated. [Embarrassed face]…
10Has anyone ever modified their ACC after getting their car? I want to ask how effective it is.
