حسن عوادة
حسن عوادة
Sep 9
Has anyone experienced the driver's door window on the Scirocco only lowering a little bit when opening the door? What could be causing this issue?
محمد سلمان
محمد سلمان2023-09-22 12:35
They all need to be lowered, otherwise the edge strip will get damaged.
بهاء سلمان
بهاء سلمان2023-09-12 19:59
Aren't frameless car doors like this?
For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
Is the severe shaking of the driver's side window when lowered a common issue with the Lingfang?
My M7's electric right middle door isn't working. It opens a little, and if I press it again, it opens a bit more, but it won't close completely. Experts, what could be the reason for this?
The trunk of my Scirocco can't be opened using the driver's seat switch, but I can open it with the key. What's going on?
The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
When the window glass in the Outlander's cabin is lowered and the door is closed with a bang, what's going on?
Volkswagen Scirocco
Volkswagen SciroccoKWD 11,000 ~ 12,000Gasoline
