Does the 2013 model of Scirocco 2.0T have cruise control, and if so, how do you activate it?
Does the top model have active braking? If so, how do you activate it? Thanks!
How do I activate the Hill Descent Control on the 2019 LTD model?
My 2013 model doesn't have a rear differential lock and cruise control. What version is it?
4To activate the cruise control on the MX-5 NC, first make sure you're driving at your desired speed. Then, locate the cruise control button on your steering wheel or stalk and press it to turn on the system. Once activated, you should see a cruise control indicator light on your dashboard. Adjust the speed using the "Set" or "Resume" buttons as needed.
5Why can't the cruise control on the LC300 be activated? It shows OFF and won't turn on no matter what I do.
6Does this car have cruise control?
7How do you activate cruise control on a 2017 Smart? I've been trying for a long time but still can't figure it out.
8Does the 2022 model of The one come with cruise control installed?
9Does the 2023 Macan 2.0T come with standard cruise control or adaptive cruise control? Can someone explain this?
10The issue with the cruise control not holding could be due to several reasons. While the indicator light on the dashboard shows that the cruise control is activated, it might not maintain the set speed.
