Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
There is power in the T60 pickup truck, but sometimes it takes several attempts to start. What could be the reason for this?
Hi everyone, sometimes my Mazda 2 sedan has a hard time starting, but it only happens occasionally. It struggles on the first attempt, but starts up easily on the second try. What could be the issue here?
The GA8 often has trouble starting and requires several attempts. How can this issue be resolved?
4What could be causing starting difficulties, where sometimes it takes two or three attempts to start?
5I have a 2016 Honda City, and sometimes it doesn't start on the first try, but it starts on the second attempt. Experts, what could be the problem?
6Why does it take two or three attempts to start the car?
7Is your car key responsive? Sometimes I have to press mine several times before it works...
8Why does my 2021 manual Santana sometimes have no response when I try to start it, requiring several attempts to ignite?
9In a 2021 manual Santana, when you turn on the ignition, the battery and engine lights will illuminate, but they disappear once the engine starts.
10Is it a problem with the ignition switch if the Volvo S40 key is turned to the second position, but there's no power and it reports an engine anti-theft system fault? I changed the ignition switch, and now it's sometimes good and sometimes bad. Sometimes the dashboard lights up, sometimes it doesn't, and sometimes it even starts automatically.
